Java problem(not run)
3 replies · 2,082 views · Started 19 July 2004
My respect to all!
I downloaded some java stuf and install it on my precious P800 without any problem!
When I tray to run those apps.Surprise!!!They don't work!
On screen appear "Starting MIDlet" and nothing happen!
What is the problem,em I miss something on my phone or...? 😡
Thanks in advance!
I get the same problem in p900
Java splash window appears and then dissapears
Any1 know a way to look at the java console to see any errors?
I've installed like 4 different java games on my P900 now, and when i try n run them the "Powered by java"-screen appears, and then disappears.
An then nothing.
What's wrong?
Well sometimes it works sometimes it doesn't. I have one java-game on it. Sometimes it takes about 30 to 60 seconds to load, sometimes it doesn't load at all. If that's the case, close the process completely, and try again.
