Does anyone know how to change the Operator Logo for 7610??
I don't know how to upload my .jpeg as an oplogo for my 7610
Help!
Thanks! 😊
Change Operator Logo for 7610
Same was as with any other Series 60 phone. The easiest way to do it is to use FExplorer (http://www.gosymbian.com); with it you can just select the picture you want and have it do all the work.
Oh ok, thanks 😃
Anyway to make it transparent?
nerdie wrote:Oh ok, thanks 😃
Nope... Not possible as of yet...
Please can I have a more detailed description. The above does not make sense to me.
I have downloaded the above software and still can't do it.
Thanks a lot.
Unregistered1 wrote:Please can I have a more detailed description. The above does not make sense to me.I have downloaded the above software and still can't do it.
Thanks a lot.
Using FExplorer, find the file you want. Then press options. Then go into file menu, then scroll down to Set as operator logo ... not actually tried it mind I must confess.
Nyxmorph wrote:Using FExplorer, find the file you want. Then press options. Then go into file menu, then scroll down to Set as operator logo ... not actually tried it mind I must confess.
Great but the logo is on my desktop and I can't find it with PC Suite.
The processes above don't say whether you are using FExplorer from in the phone to find a file already in the phone.
Sorry for being thick but I need a detailed description.
oh heck.
Right,
Lets assume you have Nokia PC Suite installed on ya PC and ya phone hooked up with the cable and thats all working.
Then, get your image file on your pc and copy it to the phone using Nokia Phone Browser. You can just go to My Computer -> Nokia Phone Browser -> 7610 ...
The image is now on your phone.
Next get FExplorer installed on your phone. You can download it from this site Software -> Series 60 freeware. You will end up downloading a .SIS file. Using Nokia Application Installer select the .SIS file and that will install on your phone.
Your now finished with the PC bit.
Now run FExplorer on your phone and follow the instructions I posted higher up.
Sorted.
