Customised Icons
8 replies · 3,123 views · Started 19 July 2004
Hi guys!
How do we make make custom icons for programs installed on our phone?
I've been looking on google for ages but have had no luck yet... I've found two tutorials on it but they were both much MUCH too advanced for me 😞
Someone PLEASE help!
TIA :P
Hektik wrote:Hi guys!
TIA :P
You can make them with Nokia Theme Studio and a decent Paint program.
But if thats too advanced then download a theme with the icons already inside and assign these icons to whatever theme you are using.
I have attached a theme with a nice set of icons. 😊
Edit: I have just re read your post and now im not sure if thats what you meant?? Lol :?
Attachments: ketix.sis (111 KB)
Whoa! Elton your themes are superb! Nice work man!
Anyway, I actually meant being able to change JUST individual icons and not the whole theme... I know there are SIS files that we can download that change the icons (using the AIF file??) but how do we make our own??
Hektik wrote:Whoa! Elton your themes are superb! Nice work man!
Thanks,
Thats what i said,if you install the theme on the phone then go into the themes menu and click on the theme you are using now,then edit the theme and you can then change just the icons!
elton wrote:Thanks,
sometimes when the theme file is corrupted , u cannot go to the theme menu after u change the theme icons
I proved some time last year that you can indeed change icons, Hektik, so no worries about people here saying you can't change them (I changed the To-do icon on a 7650 and 3650) 😊
Although it's German, I recommend Series 60 Icon Wizard, here. It will let you change the icons of applications/games installed on your phone, based on their UID number (retrievable via FExplorer or SeleQ).
So you can use Elton's suggestion to change the standard icons (Messaging, etc) and this tool to change the 3rd party ones that you've installed.
Cheers
I heard somewhere of a software called aif builder. Can anybody give a link to it or atleast upload the file.
Thnx in advance. 😊
I think the Aif Builder comes with the Series 60 SDK, downloadable from Forum Nokia.
