can you delete every single thing on the n gage, like , say i got a used n gage and it still had the stuff the other user had on it can i delete it. and also if me and my bro got an n gage each, could we both use bluetooth at the same time...
can you...
Will you please use more descriptive titles for your topics.
Yes, you just format the phone to erase everything from the previous owner. Search the forum to find out how.
Yes, you and your brother can use BT to play against each other or transfer files etc. But if you mean if you both can be connected to the same PC at the same time using BT, then no.
