Is there anyway I can export my contact list to a PC to edit and import it back to the P900? just like the Desktop program for Palm.
P900 Cantact list
Can you not just synch with your favourite PIM, edit the contacts in there and then synch back? Other than that, use the contacts manager to export the whole lots as Vcards, use a Vcard app on your PC and then bring 'em all back in again.
But I think, when it was designed, it was assumed you would be synching with a PC to acheive the same sort of thing.
Thanks. I do not want to sync with my PIM. It is just the information in my P900 contact are not well organised because I sync it with my office lotus notes, so it is very troublesome to go through one by one on the P900 to 'correct' 'delete' etc the information. I will check on the vCards option. Thanks again.
