New 7610
3 replies · 1,853 views · Started 21 July 2004
Hi guys,
I got a 7610 yeterday and I'be be grateful if someone could recommend me some apps to use. I'm going to put Agile and Opera on there, but what else do people recommend?
Also what games are good? I know Doom is available for the 7650, will this work on the 7610? Any other good ones!
I'd be grateful if you guys could share your wisdom! 😊
Unregistered1 wrote:Hi guys,
All the apps avaible for the 6600 will work on the 7610 (except for the camera and ir related ones)... So just take your pick... - Look at my-symbian for example, or handango
dabp wrote:All the apps avaible for the 6600 will work on the 7610 (except for the camera and ir related ones)... So just take your pick... - Look at my-symbian for example, or handango
why dont the camera ones work? I would have thourght that the camera ones would be compatable as there isnt that much of a change
ceanth wrote:why dont the camera ones work? I would have thourght that the camera ones would be compatable as there isnt that much of a change
You don't consider vga -> 1 megapixel a big change? - I certainly do, going from 640-480 to 1152-864 is almost four times the image size...!!
Some progs work, but they don't support the 1 mp cam for now...
