e mail
6 replies · 2,811 views · Started 26 September 2002
hello 😃
well at the end after a long time i active my e mail and its so cool the pro was on access points in data call type it was on isdn and now i poot it on analogu and its work gr8 😊 😊 now i have an after e mail pro when i dont have ir so i am sending to my e mail files so i am downloead to my pc thet send it to the e mail but he said he cant open it i try to send it on a winzip and nothing and alsow how it was downloead from the pc still nothing, i send the camerFX and he dident open it so if you can tell me what do i need to do thet it will open and work on the 7650
thanxs
[quote="oror"]hello 😃
thanxs[/quote]
I've read your post 3 times, and I think I get the gist of it. What your saying is that when you send a Program (sis file) to your phone (Via email) you can't open the program in the e-mail?
If this is the case, you don't want to send the program in a Zip file because the phone doesn't have Winzip so it can't unzip the file.
You want to send the sis, midlet or otherwise to your phone. Go into the mail, go into menu and open attachments, a list of attachments will come up on the screen, highlight the one you want to install, options and install. It will now install then save in either in your meun, or your applications depending on what sort of file it is.
You should now be able to run the program.
well yes i send it on a winzip and it dident open it so now i will try to do what you told me and i will tell you whats going on
thanxs for re so fast 😊
No thets on kemer i was at club med ther...
ah and thanxs its work i got now the cameFX the video from t mobile and two nokia games its so cool LOL 😃 😃 😃
