Or will they just disappear from my phone after a set period of time?
This one's been bugging me for a few days now.
And before you ask I don't have eFilemanager or SeleQ installed :P
S.
S.
I had the same problem, but when I swapped the sim card for another one, then changed back they were gone. So that's one way, but I'm sure there's a proper way to delete.
Here's another FAQ.
just go to the logs app, click across a tab and press clear log..
bingo.. gone..
[quote="crabman"]just go to the logs app, click across a tab and press clear log..
bingo.. gone..[/quote]
Sorry if this may sound a stupid question, but where is the Logs app?
[quote="J2theIZZO"] Sorry if this may sound a stupid question, but where is the Logs app?[/quote]
Hes talking about your caller LOG apps in the main menu....
Goto it.....then click right on the joystick....this gives you a list of all communications from the 7650!! (You can also setup filters to filter what to keep in the logs!!!)
then goto options and then clear log
That will clear all logs off the phone!!!!
Hope this helps!!
