How do!
I'm looking on ebay at the moment at a 256mb rs-mmc for my 7610.
It's a kingsmax from hong kong. Are these ok? does manufacturer matter?
Anybody know where i can get a larger capacity card from the uk?
Thanks!!
Marc. 😊
How do!
Thanks!!
Marc. 😊
Grindcore wrote:How do!I'm looking on ebay at the moment at a 256mb rs-mmc for my 7610.
Anybody know where i can get a larger capacity card from the uk?Thanks!!
Marc. 😊
Check out www.ebuyer.com - you'll get better prices from there.
And yes, I have heard that the Kingmax RS-MMC does work with thr 7610.
got mine from ebuyer. All good
If mmc is cheaper than rs mmc (i.e. more memory for less money), why not buy that...and use the adaptor provided with the 7610 to lug it in?
I am sure that i'm missing something her...i usually do! 😊
Erm...just realised what i'm missing....
The adaptor is for putting RS MMC into the phones that only support MMC...
Excuse my extreme 'thickness'!!!
