I am new to nokia platform. I want to learn about the nokia platform and specifically 9210. How do I make start?
I have got hold of the sdk. Where can I get some sample programs?
As you probably know there are two main ways to program the 9210.
First there is Java - this can be broken down into different sections. I don't know much about this, but I believe there are examples with the SDK.
For C++ I also dont know much, there are some example programs with the SDK and a further few can be downloaded from Forum Nokia (http//forum.nokia.com). I also recommend the newgroups of SymbianDevNet - you need to sign up with them and follow the link about discussion or similar.
As I said I dont know much about programming. I like to add a section to the site about it, but don't feel I know enough. Anyone like to help out?
There is also OPL, a BASIC like language which I'd recommend for beginners and on which I'll hopefully do a series. Unforunately the SDK for this is only available to professional (�100 pa) members of Symbian DevNet, although it should be released shortly.
HTH
Rafe
For C++ I'd recommend going this site
http//www.cs.tut.fi/~eerola/download.htm
He's developed some simple examples which are a LOT clearer then the supplied examples from Symbian.
Arild Bergh
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
For C++ you are going to need allot of patients and Martin Taskers Professional Symbian Programming book. Search on Amazon
