Changin from 7650 to 7610
2 replies · 2,233 views · Started 22 July 2004
Hi
I made a backup of my old 7650 to my computer and now I'm struggling to get the stuff to my new phone ( 7610 ). I mailed Nokia's support and they told me that the only solution is to use Outlook between the old and the new Pc-suite.
Is there any easier way ( ie. not using Outlook ) to get my presious junk from my old phone to my new one?
SereWiz
Easiest way is to open your contacts - select all - send as e-mail to your 7610
When you open the e-mail on your 7610 your contacts will be presented as attachments - just save them..
Or - send them bluetooth one at a time.
Best
Will
It depends on what stuff you wanna transfer. For contacts use smart V card..... to transfer via Bluetooth all the contacts together.
