There Is any way to make this sounds compatible with n7650?
Thank in advance for your help..
please see and help..
Convert the wma files to wav format and upload them to your phone via infra-red or bluetooth.
Suggestion: When converting, convert to mono, rather than stereo. This will cut down the size of the files and since you've only one speaker on the phone, you won't notice the difference. 😉
The firs file of the zip archive is already a WAV file. Does it nt work with your 7650???
Try these, I've converted the WMA's to WAV's and recoded as 8-bit Mono.
[quote="zygote"]Try these, I've converted the WMA's to WAV's and recoded as 8-bit Mono.[/quote]
Thank u soooo much 😃
Can u tell me how u do it?
Gree: Des to message to Zygote 😊
English: See Zygote's message 😊
[quote="MaleBuffy"]Gree: Des to message to Zygote 😊
English: See Zygote's message 😊[/quote]
Arghsa alla to eida.. 😉
You can use the Advanced WMA Workshop
http://www.litexmedia.com/awmaw.exe
There are plenty of other in the web!
Seach for: Convert WMA to WAV
Visit www.tucows.com and search there as well!
Exactly!
I used advanced WMA workshop to convert the files, then opened each wav in windows recorder, select file>properties and click convert now. This lets you drop the quality/size of the wav.
BTW, guys, is there any software for PC to convert .midi files to .arm files?
This is because I would like to can send my sound files via MMS, but I can send only .arm files, not my .midi files.
Thanks!
