hi everyone out there..Iam in great delima..i got this wonderful mobile nokia 6600 and iam quite satisfied and happy with it. Iam just facing one small problem.. i want to connect my laptop to internet by the help of my nokia 6600 and use it as a modem...I have installed modem software in my pc and even the pc suite..when i go to connectivity and choose modem icon and the click "connect via infra" the mobile get connected to my pc and it has also found by my pc as a new hardware and everything seems to be working fine.
After that when i go to connection manger in dial up i choose nokia 6600 as my modem and put the local number and my password and press connect.....
>>>here the problems comes<<<< the message i get is that "the computer you are connecting does not respond"... and then again my pc tries to connect but all in vail... the same message comes and when choose my pc modem i get connected to internet...can please anyone tell me that how to solve this problem and please answer soon and by the way iam having Windows Me(Mellinium) edition.... thanks for you attention.. you can even email me at [email][email protected][/email].. i'll be waiting for your answers thanks.....
With regards,
Kane 😊
Nokia 6600 Modem Connection
dear friend,
i am sure u wud know that one can connect to net using gprs service of mobile or using mobile phone as data modem and for these both rescpective service i.e gprs & fax & data serivce has to be activated by ur mobile company.
secondly one shud have phone that can have gprs and fax data features.
to connect laptop or pc to mobile phone via ir or bluetooth.
bluetooth wud be preferable as it is faster compered to ir
if u want to use ur mobile for data option then just establish connection between laptop and mobile (ir or bluetooth) then create dialup connection which u are using to connect to net via landline. and connet to net using htis connection.
if u want to us egprs then u have to set ut handset for gprs as pe rur mobile service provider settings. then from bluetooth program on laptop select dialup networking service of ur mobile device and u can connet to net. its a bit complicated but very simple... if u want to know more than email me to [email][email protected][/email]
princeoflove42 wrote:dear friend,
i am sure u wud know that one can connect to net using gprs service of mobile or using mobile phone as data modem and for these both rescpective service i.e gprs & fax & data serivce has to be activated by ur mobile company.secondly one shud have phone that can have gprs and fax data features.
I have tried connecting my laptop running windows XP home via bluetooth to the Nokia 6600; it coonects easily. Then I tried using the 6600 as a modem for connecting my laptop through it to the net using a dialup account; it connected once. I got a data transfer rate of 112kbps and was able to open sites and all easily. Morover, I was able to make and receive calls while my mobile was still acting as a modem! I was also able to connect through a Nokia 7650; only difference being I cannot make calls while it is still connected. Subsequently however, I have not been able to connect to the net through the 6600 no matter what I tried. Anybody has any idea why?
I seem to be havinga similiar problem on my 6620...
My Bluetooth link works fine, the call initiates on the phone, but I get a "connection error" message everytime I try.
The same ISP # works fine via land line and my regular modem.
lynchpin wrote:I seem to be havinga similiar problem on my 6620...My Bluetooth link works fine, the call initiates on the phone, but I get a "connection error" message everytime I try.
I also have 6620 (att) and have yet to get the modem to work.
Anyone please paste a link or offer advice.
Thanks!
mk-ultra wrote:I also have 6620 (att) and have yet to get the modem to work.Anyone please paste a link or offer advice.
Thanks!
Ok...dont know about the 6600 but 6620 I can tell you cuz...wooohooo...I have one. I can tell you what I do...perhaps itll help. Im using a belkin BT adapter..using dial up networking protocol, I input the # to dial ( I have TMO so its *99#, leave username and password blank and voila...I connect.
