"Installer: Feature Not Supported"???
2 replies · 2,295 views · Started 23 July 2004
When i am trying to remove several applications using the tools manager, it wont remove it and instead sats "Installer: Feature not supported"
i dont know why it says that
is there any other software that can remove installed applications?
@ispbonanza.com wrote:When i am trying to remove several applications using the tools manager, it wont remove it and instead sats "Installer: Feature not supported"
Just for info, is it a psiloc application you're trying to uninstall?
do the following , i landed into the same problem .
use system explorer ,Seleq , then remove the app folder from the c:/system/apps or e:/system/apps whereever u have installed .
This problem is with Psiloc apps ,so try removing the psiloc lib ,u will loose all the psiloc apps man .
Then reboot and try to remove ..it should work
