USB Connection Problems
8 replies · 4,081 views · Started 24 July 2004
Help! I cannot connect my n-gage to my pc via usb. it has worked perfectly before on winxp but now i am on a different pc running win98se. my fone is running v. 3.30 28/8/03 NME-4. Does anyone have a solution (My pc doesnt support bluetooth btw)? It has succeeded in transfering files to and from my mmc but not now. I am in crisis!
Wirelessly posted (Nokia N-Gage: NokiaN-Gage/1.0 (4.03) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0)
The USB cable is only for use with the Nokia Audio Manager, for transferring MP3 files to your game deck- in order to use the Data Suite, you have to connect to your computer using a bluetooth connection... You obviously have a USB port on your computer, since you're already using the USB cable, so why not go and buy a bluetooth adaptor/dongle that plugs into your USB port? There's plenty available! One that springs to mind is the Motorola bluetooth adaptor/dongle that's floating around, it's REALLY cheap and fully compatible with your N-Gage...
CybaCowboy wrote:Wirelessly posted (Nokia N-Gage: NokiaN-Gage/1.0 (4.03) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0)
if i need bluetooth then how did i transfer games n pics via usb before?
I don't own a computer, so I haven't tried either connection method before, all I'm doing is quoting what Nokia officially say...
CybaCowboy wrote:The USB cable is only for use with the Nokia Audio Manager, for transferring MP3 files to your game deck
You don't need any "Nokia Audio Manager". The USB connection works as a removable drive, and you can transfer ANY file from and to your N-Gage (at much greater speed than BT).
so do i just need the driver? if so can u plz tell me where to dl 1 coz im sick of using ir-t610 then bt-n-gage
If you're using Windows XP, you shouldn't need a driver as XP should automatically install the driver for you, or download it from the Internet if necessary...
nah ive got win98 and cant find the driver
