7650 infra red help pls
1 replies · 2,273 views · Started 24 July 2004
Hi
im having problems with my infra red and 7650
when i try to send a pic to the infra red, the infra red unit flashes but the 7650 says unable to connect.
im trying to send on windows 98, although the infra red is installed, it is registered as a network adapter rather than connected to usb (which its connected to)
can anyone add any input?
any help appreciated
this isthe disadvantage of infra from BT. sending files using infra you need keep your phone close to the IR, so in your case do not remove your phone while sending.... wait until transferring completed ... 😊
