Any Streetmap Software/TomTom MOBILE ?
7 replies · 3,601 views · Started 25 July 2004
hi guys,
just wandering what streetmap software is available for this phone. I know its series 60 so is there any thing available like autoroute....etc...
initially for UK
Also does anyone knoe when the new TomTom MOBILE software is coming out since it is for mobile phones, and will it support the Nokia 7610?
thanks
maddoc 😃
willbrady wrote:do a search in the shop for a product called 'wayfinder'
I second that, wayfinder is good but expensive 🙄
There is a Tomtom software that works very well in N7610 (I have tested it).
Take a look here:
http://www.tomtom.com/products/products.php?ID=232&Language=1
It�s a one city software (you buy the program with one city map), but you can buy others maps, at the price of &4.99 each.
There are available this cities of USA :
Boston, MA
Las Vegas, NV
Manhattan, NY
Miami, FL
New Orleans, LA
Philadelphia, PA
San Diego, CA
Washington, DC
Thanks almateos. But which one do i buy because there is not an option to purchase the map for the 7610. Is the 7650 or 3650 one compatible?
almateos wrote:There is a Tomtom software that works very well in N7610 (I have tested it).
Take a look here:
Boston, MA
Las Vegas, NV
Manhattan, NY
Miami, FL
New Orleans, LA
Philadelphia, PA
San Diego, CA
Washington, DC
you can use either. but if you want one to pick choose the 3650
I chose the 6600 version of the map, and works perfect for me.
