hey dr. n-gage need some help out here!
the problem is that last time i connected my headset and played music and radio. But after i disconnected the headset... it was still showing the headset sign(the one like headphones). I again connected it and disconnected it but there was no change. Before using mp3 player i also used the usb device from pc to transfer some files and at that time the headset was connected(was that the problem?).
I have tried all the solutions! turn off the mobile, took out the memory card, took out the battery.
There is one thing that is funny. In the settings->enhancements
when i access the headset properties and other properties and turn on the profile for silent etc.. and when i connect the headset it detects it and when i take it out it also turns to normal profile! :S
But still the sign always remains there and when i recieve any call i have to activate the loudspeaker bcuz i need the headset tu hear it by default!
PLZ HELP ME! it pisses me off!!!!
N-gage Headset problem! help! :(
hey guys.... cant anyone solve this problem?? i am really getting irritated by this.. i cant even talk properly on the phone i have to activate loudspeaker to talk everytime!
please find a solution and post it here! thanks!
hey
just read ya message. sounds to me like it may be a software problem. never experienced anything like that before myself. The best thing to do is send ya fone to a noka service centre.
SAbz
I got (and have) the same problem on my n-gage...the problems does not come from the software, but from where you introduce your headset...The thing you need to do is insert a needle under the methal thing that's inside it, and move it a little...it worked for me (I don't think there's any harm you can do to it, cause I was ruf on it to and nothing bad happened :tongue: ) ...it reappears from time to time , so I have to do it again like once a week....
But if you want a full recovery, I suggest you follow doctor n-gage's prescription....
i got dis problem b4 bro.....
just back up ya stuffs and reformate ya ngage ok...
mostly problem are MP3player... try to use mp3 Vault version 1.00 base and stereo.
reformate button *7370# and code number 12345
regards.
Do a backup, and soft format the phone. Should work.
it's not a sw problem,only hardware.i have the same problem.i say this bcuz i've formated my fone after the problem apeard and no result ..it goes away once in a while but it cames back😊hav'nt tried the needle solution though..
i'll try it and post the result..
cya
the needle solution worked for me😊))cooll..i will take it though to a service center to make sure i dont get this probl again....
