Hi All,
Do you know the default shortcuts which are preset to 'Camera' and 'Orange' on the two action buttons (when you are on the normal front-end screen, with spiderman looking at you all proper cool and that!)...how can i change their functions i.e. have Calendar and Messages there instead?
I have Fe Explorer installed but couldn't work out how to do it - is it possible?
Thanks.
fauji wrote:Hi All,Do you know the default shortcuts which are preset to 'Camera' and 'Orange' on the two action buttons (when you are on the normal front-end screen, with spiderman looking at you all proper cool and that!)...how can i change their functions i.e. have Calendar and Messages there instead?
Thanks.
If you from the Menu go to Settings-Telephone and choose the Waiting position you can change options for right and left button.
Hope this was you were asking for
Have a nice day,
Thanks starlet - that worked a treat!
