Hi everyone. I have a Nokia 3650, but I'd misplaced the CD that came with the phone sumwhere. I have a friend who has the Nokia 3660 CD. Well, I'd like to know if I install the PC Suite of 3660 CD on my Computer, and try to connect my 3650 phone via infrared, will it work? (Because I'm not sure whether PC Suite made for 3660 will work with 3650).
Thanks!
Rohit
will 3660 pc suite work with 3650 via infrared
NOt sure if you can use that PC suite, but in case you have lost the CD, you could download a copy from the Nokia website
I don't have such a fast connection to download 30MB! I need to know the answer yes or no quickly for my friend is leaving for London, and he's taking the CD with him.
rohit
My answer to your question is "I don't know".
But the phones are so similar I'd be very surprised if it didn't work. Best bet is to install the software and try it, I can't see as you can do any harm by trying.
If you're concerned about it, install the software before your friend leaves (or make a backup CD) & wait for more definitive replies.
Good luck!
