Bluetooth
4 replies · 1,884 views · Started 28 July 2004
Please help me with this, i am getting my nokia n-gage qd very soon and i need to know about this 'bluetooth'
when it comes to me in the box will it have a bluetooth adapter or something so i can plug it in to my computer?
what do i have to do to transfer stuff! What is bluetooth!
Thanks,
Bluetooth is a wireless standard to let portable devices like phones and pda's connect to each other. It is the successor to infrared but then much better.
To connect the QD to your pc you will need an adapter which you will have to buy seperately. They are not that expensive - around 30 Euro here - and you can use it whith every bluetoothenabled phone. Bluetooth wil integrate itself with Windows explorer after you install the adapter and you can use file>send to>bluetooth>Nokia N-Gage QD to send anything to your N-Gage
jona wrote:Bluetooth is a wireless standard to let portable devices like phones and pda's connect to each other. It is the successor to infrared but then much better.
My pc recocgnized my n-gage qd
but he can't connect, it says: "cant connect to device"
can someone explain briefly how to configure your n-gage qd with your pc?
i have a sitecom usb adaper first class ( 100 m range )
please help me out
solid reptile wrote:My pc recocgnized my n-gage qd
please help me out
you must authorize the pc from the QD. either u go to the bluetooth menu and set it permanently authorize or select yes when promted by the phone
