Hi guys I'm new here ...
Bought myself an nokia n-gage QD and like anyone else had my configuration settings for WAP and MMS send to me by my provider . Now when I wanted to browse an wap link my n-gage gives "Connection Timed out" I called my provider several times to see what they could do abot it , but everything is fine according to them ! I have GPRS connection but when I try to open a page the error occurs !
Can anyone help me please ?
Thx
Greetz
Web Connection timed out on QD!?
I used to have that problem too, i suspect your problem might lie in your advanced settings. Coz tho i had obtained the settings from my provider, the settings only had the basic settings set up, the advanced settings were somehow left out. You might want to check if your provider has a website that tells you how to manually configure the settings yourself, then go through every setting both basic and advanced yourself. Hopefully it solves the problem.
Had my connection settings manually installed , still the same !!
Heyz, i got this problem too. Dr@n|xX, which service provider are you using? mayb you can help me if we using the same service provider. i can't understand the advanced settings.
I had this issue for ages, in the end I figured something must be corrupted, so I backed up all my contacts and files from My N-Gage QD hadset and formatted it Keying *#7370# and then entering my lock code (Default is 12345) This clears all settings and content from the phone memory and returns it back to the settings from out of the box.
I then went to Nokia.com to get the settings sent to my phone:
http://www.nokia.co.uk/nokia/0,,54551,00.html
Hope this helps you all!
Andy
