Hello there, how do i go about sending a movie to my mmc and not my inbox? should i purchase a card reader?
i have a 128mb integral mmc.
Thank you for your time.
Regards
Corporal Shearer
Regards
Corporal Shearer
i take it you're sending the movie via infrared or bluetooth?
all you need to do is move the file from your mailbox onto your memory card after you have recieved it using a free program called Fexplorer. Can't remember where you get it but i bet its the top result from a quik google search.
hope this helps
oo_oozee_oo wrote:i take it you're sending the movie via infrared or bluetooth?all you need to do is move the file from your mailbox onto your memory card after you have recieved it using a free program called Fexplorer. Can't remember where you get it but i bet its the top result from a quik google search.
hope this helps
Or set your incoming message memory to 'mmc' and simply click 'save' on receiving the message and it will store in mmc!
And you will now have a bigger 'inbox' size,to recieve bigger files through it!
ps: If you want fexplorer, visit the 'shop' above. (Its Free)
your help has been much appreciated.
With regards
Cpl, Shearer
