Photocal + Stopwatch Probs
3 replies · 2,188 views · Started 28 July 2004
hi all,
i downloaded and installed from the symbian freebie software rafe site the following: photocal and that stopwatch/timer application.
the trouble is when i open them on my 7610, they don't work...they literally close immediately after they have opneed? whats the problem?
thanks.
PhotoCal is an OPL app - have you got the run time installed?
If not there are some times problems between series 6 phones though the 7610 has been very good so far. You might try contacting the authors.
I used the software on an N-Gage when I wrote the freeware piece.
Rafe wrote:PhotoCal is an OPL app - have you got the run time installed?
Hi Rafe,
Thanks for replying...
Where can i get the OPL app - will the one at: <http://opl-dev.sourceforge.net/oplseries60.html> do the trick without messing up my phone? And alos, when you say the 'run-time' what do you mean?
You're dealing with a IT person here...IT meaning : Information I lli T erate!
Thanks in advance for any helpful info Rafe.
The runtime is what allows OPL program such as PhotoCal to run. The URL you mention is the correct one. I haven't tried it myself on a 7610, but I assume it will work.
