I had just d/l a facewave program and the n-gage monkey ball to my 7610. The program and the game works fine but i can't turn on my camera or web services.
Have i accidently deleted some files away?
The game and the program can't be corrupted cos i did a test before d/l to my phone.
Argh... The camera had disabled, what is the purpose of having a 7610 since it can't take quality pics?
Can anyone give me some ideas of how to enable it? :frown: ?
Pls........
Can't switch on my camera function
Did you try uninstalling those two programs.
I've heard that facewave can cause problems, but not disabling the cam?
Perhaps it that money ball from the n-gage.
Will
I remove the programs but it still had the same problem....
Later i delete the files found in the lib n it had no more problems....
The sad thing is that u can either use the camera or the facewave.
What a waste to let go this program.
Haiz...
Cheers!
