For some reason, I seem to have turned off the snooze function on my alarm? Any clues about how to re-enable it please?
7610 alarm snooze?
If alarm is ringing and you press "snooze" it will be repeated after 6 minutes, but if you press "stop" it will stops and cannot be enable any more. Only thing you can do is, set a new alarm or new alarm time!
No I have the same problem too!!
The first time I used snooze, it worked fine. However ever since, the option is no longer there to snooze after the alarm has gone off the first time!
Does anyone know a way to bring the snooze option back?
Thanks x
RS77 wrote:If alarm is ringing and you press "snooze" it will be repeated after 6 minutes, but if you press "stop" it will stops and cannot be enable any more. Only thing you can do is, set a new alarm or new alarm time!
It seems to be some kind of a bug in the Clock app (setting a new alarm doesn't reset the "snooze counter"😉. Restart the phone and the "snooze counter" resets. I don't know if it has been fixed in newer firmware releases for the phone yet.
