plinkykev HELP ME
22 replies · 4,244 views · Started 30 July 2004
plinkykev I GOT MY SENDO X TODAY OK AFTER I RECIVE IT I WAS PLAYING WITH IT AND I PUT MY MMC CARD WHAT I USED FOR MY OLD SIEMENS SX1 AND BY MISTAKE I WAS PRESING RESTORE FROM THE CARD AND I GOT EVERYTHING FROM THE MMC CARD ON THE PHONE THE GMAES AND ALL THE APLICATION BUT AFTER I RESTART THE PHONE IS NOT WORKING :frown: IT SHOWS ME THE SENDO LOGO AND IS NOT GOING TROUGHT,PLS HELP ME IST THERE A SAVE MODE BY PRESING SOME BOTTONS OR TELL ME WHAT TO DO??,I DON'T HAVE HERE IN CANADA A SENDO SERVICE SO WAHT SHOULD I DO PLS HEL ME MAN U WORK FOR SENDO IT HAS TO BE A SOLUTION :frown:
Nutzu wrote:plinkykev I GOT MY SENDO X TODAY OK AFTER I RECIVE IT I WAS PLAYING WITH IT AND I PUT MY MMC CARD WHAT I USED FOR MY OLD SIEMENS SX1 AND BY MISTAKE I WAS PRESING RESTORE FROM THE CARD AND I GOT EVERYTHING FROM THE MMC CARD ON THE PHONE THE GMAES AND ALL THE APLICATION BUT AFTER I RESTART THE PHONE IS NOT WORKING :frown: IT SHOWS ME THE SENDO LOGO AND IS NOT GOING TROUGHT,PLS HELP ME IST THERE A SAVE MODE BY PRESING SOME BOTTONS OR TELL ME WHAT TO DO??,I DON'T HAVE HERE IN CANADA A SENDO SERVICE SO WAHT SHOULD I DO PLS HEL ME MAN U WORK FOR SENDO IT HAS TO BE A SOLUTION :frown:
Hi Nutzu,
OK, you CANNOT restore from the SX1 (or probably any other S60 handset) to another one, they are all a little bit different. Don't feel too bad, someone in our office tried this too, to see if it worked or not. Well, it doesn't. I will raise a FAQ for this to our support team, just so no-one else has this problem in the future.
To fix this, power on the handset while holding down the " 5 " key.
It will then ask to "CLEAR all memory ?"
Press the LEFT soft key (tick) to do this or the RIGHT soft key (cross) to cancel.
This will WIPE the handset back to the original settings, so anything you put in will be wiped, and will need to be re-entered, but hey, at least it's going again.
Any games / programs should be reinstalled on the new handset anyway, so they are loaded up OK on the new one. Sync the SX1 with Outlook, then sync Outlook with the Sendo X to get your contacts and calendar back on there.
To everyone else, this is the LAST resort to recover the handset (other than going to a service centre) so be careful to do this only when needed.
Regards,
plinkykev
plinkykev wrote:Hi Nutzu,
Regards,
plinkykev
thx again i fixed the problem before i read u'r post i fond the unswer to the sendo page but again THX
plinkykev another problem is the camera,when i try to make pictures the screen it turs purple or green and bouncing to normal after few sec and again to those colors i think is the fw problem, what do u think pinkykev??u guys can fix it with the new fw??
I have had the same experience as Nutzu. When the camera first turns on, bringing up the image, the colors are quite distorted. Also happens after taking a picture and pressing "Continue" to take another picture; as the camera lens is engaged again, the same color distortion occurs. The distortion clears up after about 3-5 seconds and becomes normal.
Hopefully a FW update will correct this.
--gRavY
gOOdgRavY wrote:I have had the same experience as Nutzu. When the camera first turns on, bringing up the image, the colors are quite distorted. Also happens after taking a picture and pressing "Continue" to take another picture; as the camera lens is engaged again, the same color distortion occurs. The distortion clears up after about 3-5 seconds and becomes normal.
--gRavY
mine is like this inside is horible it has the distortion with pink-purple color and is not comming back to mormal if i shot outside the camera is ok not perfect so outsite is ok 😎
DUDES ! ik have also some problems with sendo-x
smartmovie don't work, but ok, i see the guys from lonelycatgames are checking it out. Also the mp3 player from lonelycat doesn't work, i just don't get sound !
smartmovie: the second demomovie i can play, but the first hangs and i never get sound.
i think personally it's the sound codec for AMR that's very bad.
wayfinder for example: really horrible what sound quality.
also when somebody calls me they hear me very bad. today my mother called me saying the receiving was horrible: cracks and so on, and i have exactly the same problem at my side: sound when i call somebody is bad !
when i play movies that i converted with the nokia symbian 60 converter the sound also ticks. it's like there is a cracking in the back, can't really explain it.
mp3 is no problem at all ! crisp sound ! this means it HAS TO BE the codec for AMR sound, which also makes the smartmovie go bad.
what is also a problem is the free memory. i mean, come on , 5000kb memory only ? what if we want to play heavy games or use heavy applications?
i heard somebody his adobe won't start because too less memory.
he says i can free some memory by restarting, but the restarting procedure is explained wrongly in the manual.
also a problem i have: gprs connection breaks sometimes. but connecting to the GPRS network costs 0,50 euro so i lost 7� today just reconnecting...
i never had this with my previous phone ! gprs connection is plain bad i think. a lot if times i see the G but sometimes it has a frame on it, sometimes it is outlined when i want to have a connection all the time 😞.
anoter bug: try the foto editor in dutch language: it won't start: big bug !
i had network connection problems also: i was doing wayfinder when it gave a network error and the whole phone jammed on me! I had to take out battery and everything!
the application mobiclip won't even startup: it hangs totally.
i really hope i didn't buy a bad phone 😞. the sendo seemed so cool, let's hope we get a solution soon!
SPEEDMAN wrote:DUDES ! ik have also some problems with sendo-x
i hope plinkykev is gonna read this and is gonna show it to those developers to fix the problem in the future with that update they say are comming out :frown:
yet another BUG on the sendo.
a lot of apps won't work with a link on the panes !!!!
the lowtek showcase that pinlyev offered here, or the agile messenger and many others
just won't work with a link on the panes.
please fix that with an update,
thank you 😊
At the moment, only programs installed to the MAIN memory will be allowed on the panes.
The programs you are trying to do must be installed on memory cards. Is that the case ?
Regards,
plinkykev
plinkykev wrote:Hi,
Regards,
plinkykev
what about the camera pinky??is gonna be fixed in the next fw update and when??
Hi Nutzu,
I'm not sure about the camera problem. I'll talk to some guys tomorrow and let you know.
I hope it is fixed on the upgrade - sounds weird !
plinkykev
plinkykev
is like this out side is working ok but inside is like blue-purple dark and blinking to normal from time to time but is not normal,only when i shoot outside the colors are normal weard cuz i have the n7610 and i can't compare it with that :frown: i hope in the next fw and i hope is gonna be soon they gonna fix this bug,so far only the camera and the smart movie is bug in me in rest i don't care
plinkykev wrote:Hi,
Regards,
plinkykev
no plikykev
that is NOT the case. i haven't received my SD card yet. ordered it, will probably arrive tomorrow.
all my apps are installed on my phone memory.
plinkykev, my camera is just very slow to show true colors. It takes 4-5 seconds sometimes to go from total darkness to almost negative-like coloring to proper color.
Thanks,
--gRavY
SPEEDMAN, how big of an SD card did you buy? And how much if you don't mind? And where did you buy it?
Thanks,
--gRavY
... and what color is it? How much does it weigh? What was the phase of the moon when you purchased it? ...sorry! I was asking so many questions there in the beginning I guess I just got carried away! :tongue:
gravy add me through msn
[email][email protected][/email]
how big? 512 mb
where did i buy? The netherlands.
i live in belgium, but VTA is less in holland.
which shop?
http://www.digitalwarehouse.nl/
which card?
Sandisk 512MB SD Card Ultra II Card fastest sd at 9MB/S
what is the link to it?
http://www.digitalwarehouse.nl/estore3/content.php?Art_ID=274&taal_ID=NL&H_ID=&S_ID=113
are you happy now ?
yes
will you be filling up Speedman's bank account with everything you have?
yes you will
do you feel like saying no to the previous 2 messages?
yes you do but the feeling is wrong, say yes and happiness will come your way.
LOL! :tongue:
But how can I possibly purchase one myself without knowing the phase of the moon??? :?
--gRavY
Sure enough, SPEEDMAN. It told me not enough memory available to run Fifa 2004. I loaded it onto my mem card but still nothing. Also, after that, I had trouble running PC Connect. It wouldn't recognize the X and connect.
--gRavY
i had the same.
the best thing you can do is delete it manually.
go to menu, tools, appl (the second option)
there you can delete it by selecting it. it's possible that deleting one fifa file clears them all, but i think you have to delete them one by one.
if you want to make free mem you can do 2 things.
1st => install the free and most useful application ever FExplorer. there in the options, you can select tools and then the last option is compress memory.
select that one and it will make some kb's free.
if you want more free, go back to options in fexplorer and select gsm, then restart. restarting will go automatically and after you will have a lot of mem free, almost 5000kb :icon14:
and more bugs:
reserve copy won't work with my mobile. (its the backup copy or i don't know how it is in english 4 u )
then it says on my phone (after pc connect gave an error😊
app closed extxpadapter_0
0808E5C
and then
app closed down mstreamman
and it keeps repeating these 2.
That is exactly what I have on my Nokia 6600 after connecting to my Computer.
Do you already have a solution? I don't.
Kind regards,
Johan Knopper (The Netherlands)
SPEEDMAN wrote:and more bugs:
0808E5C
and then
