How Do U Find Out Your Lock Code
3 replies · 2,758 views · Started 31 July 2004
does anybody know how to find out the lock code of your fone.(i have a nokia 7650)
ANY HELP WOULD BE REALY APPRECIATED
the default lock code is 12345 .you should really do a search for this kind of question as it has been asked and answered many times .
gadget
i tried it but it dont work.has every mobile got a diffferent lock code?and is a lock code and a default lock code the same thing
please forgive me for being so dumb.its just that i dont know many things baout the nokia 7650
any help wud be appreciated
the default lock code is the one that came with the phone . All nokias are set to 12345 when there new out of the box but if you or someone else has changed it and you dont know what it is then your a bit stuck .you might have to get the firmware flashed at a nokia service centre or do a hard resset but im not sure the latter will reset the lock code .
gadget
