You don't need CodeWarrior to run the emulator
0 replies · 2,373 views · Started 27 September 2002
But you DO need CodeWarrior to compile and test your OWN application against the emulator. So if you have a device, you can always compile against target and test on that platform. And the CodeWarrior solution is more integrated towards SymbianOS development, more than the MS Dev solution ever has. But still .. it is CodeWarrior. 😞 So don't expect Linux source to compile for it just like that.
