Email compatibility
1 replies · 2,231 views · Started 27 September 2002
Does anybody know about the compatibility of the P800 email client with the MS Exchange server? And if the server doesn't have IMAP enabled?
Guessing:
1. If you are syncing from a cradle, then there is a possibility via SyncML.
2. Remote access? P800 does POP, IMAP and SMTP. I asked the question about IMAP of Symbian ages ago, and it's only just appeared. Outlooks own client uses RPC to the server, and I have not heard of a provider for this for Symbian. You can send to Exchange via SMTP but we will be limited to IMAP (or web gateways) for reading . Unless someone writes the provider of course :cry: .
