Hello all!
I have recently installed a few programs and now when I power on my X I receive the message "App closed CbsServer". I am wondering two things:
1. What is the CbsServer and what purpose does it serve?
2. What program have I installed that is overriding it?
(Programs installed: FExplorer, Worldmate, eProfiles, miniGPS, FSCaller and My Savers/ScreenSaver)
Thanks!
--gRavY
CbsServer?
As a s60 developer i can tell you that cbs server is the part of the phone that looks at the cell broadcast information. I'm nearly 100% sure that Mini GPS uses this information. However, I guess that Mini GPS was written specifically with a 3650 in mind, so mini gps is either calling something that sendo dont support, or more likely do support but in a different way.
I suggest that you either remove mini gps ( its a terrible program anyway ) or email the makers and ask if they have tested their code on a sendo x, and have any updates to ensure compatibility.
Hope this helps,
MW.
