how to get hotmail on my p800
5 replies · 2,266 views · Started 02 August 2004
Can i set my p800 up to recive my hotmail e-mails?
if so how do i go about doing it.
thanks
i just found a exelent site for getting hotmail,msn,yahoo and AOL e-mail acounts on your phone.
sign up to https://www.mymail.ie/ and it is very simple so it wont cost alot to read emails.
tell me what you think. 😉
It looks okay. But assuming hotmail is set up the same as Yahoo, you should just be able to enable it for POP3 access and then set up a messaging account on your P800 to access it through the e-mail client. Have a look around hotmail and see if you can find reference to "POP3". That should tell you how to go about it. Alternatively, try searching on here. 9 times out of ten someone will have already done it and written about it on here. And the search facility is very good.
Bassey wrote:It looks okay. But assuming hotmail is set up the same as Yahoo, you should just be able to enable it for POP3 access and then set up a messaging account on your P800 to access it through the e-mail client. Have a look around hotmail and see if you can find reference to "POP3". That should tell you how to go about it. Alternatively, try searching on here. 9 times out of ten someone will have already done it and written about it on here. And the search facility is very good.
thanks for that. i have already searched an you have to pay to have pop3 for hotmail, so i think ill use www.mymail.ie for now.
Take a look at OneMail.ToGo
Get a Free Trial from [email][email protected][/email]
It do all these using your standard P800 Mail Progarm.
No need to download anything
It makes life much easier for you by
1. convert all HTML Email to Text, no funny characters
2. It reduce these HTML Email size to about 1/10, save money and time
3. It supports full attachment
4. You can also use it to read any webpage, like Avantgo
Regards
Bn
