some one pls help i had a problem with my 6600...the menu button and the camera button makes the same work or i can tell this when in standby screenn my camera key makes the work of menu key and i bring my phone to phone seller he said that there is nothing wrong but i need to format my phone but i forgot my security code how can i make this without my security code or can i reset the security code? if u help me with this i will be so happpy...how can i make hard format to my phone
pls help urgent
power off the phone! when you power it back on, press and hold the green button, * (star) button , and 3. if you done it correctly the phone will format itself. hope that helps! alternitavly you can mail me: supermansa46@hotmail
i will not check here for your reply
David de Fortier
standard code is 12345 anyway
it's work with me so try it and u will be happy
