Has anyone seen an application that allows your to scroll from the top of a list to the bottom. IE, on a pop-up menu of 7 items you have to scroll 7 items down instead of 1 up.
Or in a list of 30 SMS messages you have to scroll 30 to the bottom instead of one backwards.
Or in a screen with 8 page tabs, why can't you get to the last tab by going one tab to the left instead of 6 to the right.
A link or application name would be great.. Thanks
Brad
On a 7610 (and all other phones based on Series 60 2.1 and later) lists & menus wrap like that already.
Probably not easy, if not impossible, to make a separate application to make that happen on phones based on earlier versions of Series 60.
I have a 6600, I thought it was a series 60 2 phone...
The 6600 is a Series 60 release 2.0 phone. The 7610 is based on Series 60 release 2.1 (also called Series 60 Second Edition, Feature Pack 1 by Nokia).
The behaviour I mentioned appeared in 2.1, so it does not exist on the 6600.
