Sweden
7 replies · 2,287 views · Started 03 August 2004
suppose the sendo x doesn�t get available in sweden soon, and i buy it elsewhere on the net... can i make it work with some operator in sweden, say comviq... regarding to mms, gprs settings?
Darko, I would suggest emailing Sendo (support section @ Sendo.com) asking them who they plan to work with directly as a network provider. Your chances of success within the network would increase. Also, you might wait another week or so if you can. They are working out the bugs right now and for some of us who have the X already, the experience is more bitter than sweet at times. 😉
--gRavY
It should work with any GSM operator on whose network phones like the 3650 or the N-Gage work. Exact same GPRS/MMS settings would apply as they're all based on Series 60 1.2.
Darko wrote:suppose the sendo x doesn�t get available in sweden soon, and i buy it elsewhere on the net... can i make it work with some operator in sweden, say comviq... regarding to mms, gprs settings?
Hi Darko,
The handset should work OK in Sweden, although Swedish is not a language on the handset, so you would have to use English / German / etc.
To configure it, use the Nokia site if needed, and just "pretend" the handset is a 3650, entering the network info etc. The configuration messages will then arrive and should set the handset up OK for you.
Regards,
plinkykev
For Sendo Online Support visit http://sendo.custhelp.com
For OTA configuration visit http://www.sendo.com/config
Although they dont have Sweden listed on the OTA i have requested this from Sendo and they have passed it onto WDS who provide the OTA configuration website. These usually take a couple of weeks to go live.
In the meantime, as Plinky said try using the Nokia site as this is also provided by WDS and has Sweden listed.
The phone will probably work in Sweden, I bought one from France, and it is working just fine in Norway (Telenor Mobil). There are scandinavian letters embedded in the phone (at least all the norwegian letters; � � �, are present,
and I think the swedish and danish are as well), even if there is no scandinavian phone-language embedded.
good luck
I live in sweden.. an it works great here mms gprs everything works (telia).. but I am selling it it any one is interessting.. I got my code for the neonode N1 😃
how about Sendo x VS neonode N1??
viddee wrote:I live in sweden.. an it works great here mms gprs everything works (telia).. but I am selling it it any one is interessting.. I got my code for the neonode N1 😃
IF anybody want, they can by my Neonode N1 😉
