Hi all - I have heard that there is a patch written for some series 60 phones which have bluetooth to allow them to use Wifi. So i have two questions,
1) Is there a patch that would work with the 7610?
2) Does the patch stop you from using normal bluetooth?
Thanks for all help guys,
CacheUK
No, there is no patch that can make a Bluetooth radio & related software compatible with WiFi/WLAN.
Even if WiFi/WLAN uses the same unlicensed 2.4GHz radio band as Bluetooth (or microwave ovens, many mediacl equipment, etc.), they are not compatible and cannot be made compatible with just a software change.
N/A wrote:No, there is no patch that can make a Bluetooth radio & related software compatible with WiFi/WLAN.Even if WiFi/WLAN uses the same unlicensed 2.4GHz radio band as Bluetooth (or microwave ovens, many mediacl equipment, etc.), they are not compatible and cannot be made compatible with just a software change.
Hi thanks - was going to link you to this http://www.mobitopia.com/20040401.html
However i just looked at the date of the blog.....
April 1st..... ARGH! 😃 Thanks anyway
