The Snooze Button has dissapeared for the alarm on my Nokia 7610. It was there for a while but now it has dissapeared altogether. Has anyone had a simlar problem or do you know how to get it back? :?
Dissapearing Snooze Option on 7610
Seems like there's a counter that gives you 5 (or is it 6) snoozes that doesn't reset when you create a new alarm.
As a workaround, if you reboot the phone, the counter resets and you can snooze again.
A real fix would have to come from Nokia in a new firmware release, but perhaps someone could track down where the counter is stored, and figure out to clear it without having to turn the phone off and back on again...
N/A wrote:Seems like there's a counter that gives you 5 (or is it 6) snoozes that doesn't reset when you create a new alarm.As a workaround, if you reboot the phone, the counter resets and you can snooze again.
Is the new firmware for 7610 out anyway?
Depends on how you define "new". From a small subset of users, there seems to be at least two versions out: http://www.allaboutsymbian.com/forum//forum/thread/26369/
