Nokia 7610 Vs 6630
15 replies · 5,236 views · Started 04 August 2004
Can One One Tell
Which Is Better
The Current Nokia 7610
Or
The Upcoming 6630 .
<thanks In Advance>
<cheers Mate>
size wise there is nothing in it.
The main differences are:
The 7610
has 8MB internal memory
has 1 megapixel camera
has 4x digital zoom
can record up to 10 minutes
The 6630
has 10MB internal memory
has 1.3 megapixel camera
has 6x digital zoom
can record up to 1 hour video clips
It also comes with a stereo headset in the sales package
I personally prefer the keypad on the 6630
The downside to waiting for the 6630 is that it isn't planned for release till the 4th quarter of 2004 and thats provided that there aren't any delays that push it back to 2005
as there is not much diff in 6630 and 7610
if u r a GSM user there is not difference but of the camera is 1.23 instead 1
internal memory is 10Mb instead of 8 and 6x zoom istead of 4x(Digital Zoom)
if u r using 7610 then i will sugest that there is no need to upgrade.
as there is not much different
but being 6600 or 7650 or 3650 user
they will feel the difference....
Don't forget it's is UMTS (3G) too (although that isn't much use to most of us yet) and has an upgraded OS as well. And stereo is nice offcourse!
and more quality fotos because have more focal distance and a bigger diafragm lents.
can take photos in movment and the time of focal aperture its configurable
nokia 6630 "accelerate your image"
the nokia 6630 hace a more quality smooth video (~15 fps)
nokia 6600...7610...etc etc... ~7.5 FPS
Nokia 6630 posibility to view TV (streaming) 3G (i'm sure that this service will be expensive)
Delta737 wrote:Don't forget it's is UMTS (3G) too (although that isn't much use to most of us yet) and has an upgraded OS as well. And stereo is nice offcourse!
If you live in Australia, choosing a 3G phone is a good idea because all the mobile phone carriers will have 3G networks by 2005
An other cool feature of this phone is that you can hot swap the MMC
In which resolution, 176x144?
Since you guys are comparing N7610 and N6630, i was wondering if someone can help me here. I'm confused between N6630 and N9500.
Ofcourse, i'd like a ncie cmaera, so i'm inclined towards the N6630, but at the same time, i'd use the GPRS, and a little bit of PDA functions too, like To-Do and Notes stuff, and loads of email.
Would you think a N6630 would be okay for all the above i mentioned.
Cheers 😊
Well, the 6630 can do all the things you mention (although writing mails on the 9500 is easier off-course because of its keyboard). If you need Wifi/WLAN though, the 9500 is for you.
Thanx Delta,
Since the N6630 has hotswap capability, i assume you can even put an extra WLAN card, right? Any idea's about how much would the N6630 costs when its launched?
garcons50 wrote:Since the N6630 has hotswap capability, i assume you can even put an extra WLAN card, right?
No. MMC is only a memory card interface. No I/O, so no WLAN cards or anything like that through an MMC slot (hotswap or not).
I'm guessing a bit here, but I expect the 6630 to be around 500-600 euro and the 9500 to be around 750-900 euro
N/A wrote:No. MMC is only a memory card interface. No I/O, so no WLAN cards or anything like that through an MMC slot (hotswap or not).
Thanx N/A. Happy realisation struck me later when i realised to have WLAN card, you need SDI/O which the O2 xda 2 has. I soemhow got mixed up.
Cheers 😊
Delta737 wrote:I'm guessing a bit here, but I expect the 6630 to be around 500-600 euro and the 9500 to be around 750-900 euro
500 Euro, not bad!!! Fits my budget 😃
you can use 6630 to write easily. Use the wireless keyboard.
Hi guys, does anybody know when the Nokia 6630 will be avaliable on the 3g network in Australia, i am dying to fing out. Thanks
