I think I just messed up ... I just installed MagicThemes 1.0 on my A925 ... yeah I know I realised (after) that it was written for UIQ 1.0, and now my phone crashes on the way up.
Is there any way that I can remove the offending item, or do I need to re-flash my phone.
How would I go about re-flashing the phone?
Alain.
This is EXACTLY what i did to my A925.
There is nothing you can do, unless if somebody out there can get their hands on the firmware files so we can self-flash.
If you do this, you've got to go into the Motorola repair shop with your contract, and say that "the memory has been corrupted" or something, then they'll do it under warranty 😃
alainmoran wrote:I think I just messed up ... I just installed MagicThemes 1.0 on my A925 ... yeah I know I realised (after) that it was written for UIQ 1.0, and now my phone crashes on the way up.Is there any way that I can remove the offending item, or do I need to re-flash my phone.
Alain.
try to download afile manager like seleQ so youcan remove it from your phone or make a format on your mobile
