Document viewer
6 replies · 6,731 views · Started 05 August 2004
Does anyone, especially those who have the X, know if you can "edit" the documents that you are viewing?
euphoriauk2003 wrote:No it's a document viewer
sendo x is a phone with an operating system on it.
if symbian 60 (the OS) is strong enough to make an edit program run, it will be possible.
stay tuned 😎
With QuickOffice software you can edit Word, Excel and (perphaps) PowerPoint documents on your Sendo X handset...
Matthia wrote:With QuickOffice software you can edit Word, Excel and (perphaps) PowerPoint documents on your Sendo X handset...
Grazie Matthia!
I could not install quickoffice, because the new quickoffice v.2.0 call for OS 7 or later.
Is there no way to get an older/an compatible version? :frown: :con?
quick office v2 worked on my x, well basically i just installed it, and ran the prog, didnt try editing anythin, but it definetly showed my word documents, then i uninstalled cuz the prog does take alot of space, and i dont really use MS office progs that much
