Why App.closed MediaServer
3 replies · 1,986 views · Started 05 August 2004
I have the same problem with you when recieve a messsage?
No Idea ??
Nobody else have the same prob ?
Give me some advise pls 😞
thanks
probably some lib is broken :] Try *#7370# and install games from the beginning.
And I have observate and discovered that Tony Hawk Blz version destroy's FPS games like CAll of Duty :}
Game is saved in \system\apps\ and the program extentions (.dll) are saved in \system\libs.
All the games have a .dll called gamecomms.dll which is vital for the running of the game, otherwise you just get a system error and the game won't start.
There is no way to overcome this, you can't rename gamecomms.dll, i tried that and it still has a system error, your best bet is to get a new memory card.
However, certain games can go on the same mmc card. I have two 128mb mmc cards, on one I have Call Of Duty and Ghost Recon. On the other I have:
Tomb Raider, Tony Hawks, Splinter Cell, Red Faction, Asphalt and Pandemonium.
If you don't want to spend much money on mmc cards then you can go for the smallest capacity the game will fit on, Call Of Duty will fit nicely onto a 32mb, Ashen will fit onto a 16mb.
Hope this helps you.
As for the Media Server msg, I got that to, i think its just the loudspeaker driver deactivating when you leave a game, not sure though.
