Hi, I accidently deleted some of the c: folder in my ngage. It was deleting for about 10 seconds. It seemed to basically reset the contents of the fone (like sound settings ect) but i have found that the sound doesn't work properly since (in things like go-boy+) , my alarm only beeps once without vibrating and when i recieve a message, the fone won't vibrate (eventhough it does when i recieve a call). Will reseting the fone with the *#7370# (i can't remember if thats correct) fix this?
!!problem, removed a folder!!
oops, this probably should go in the ngage section. Sorry, i'm new to this fourm.
