o2 active uninstall?
20 replies · 6,551 views · Started 05 August 2004
got a unblocked o2 sx1 mclaren... only problem is its from germany and I dont use o2.. was wondering how I go about uninstalling the o2 active thing... so far all I can figure out is that there's a option to uninstall in the tools bit at the botom right.. it tells you some instruction about deactvating it (was able to do this) and then going to tools-> prog. manamger and uninstalling (can't figure that out.. can't find where it is?)
any help?
heres what it says from the uninstall menu on the phone
german -
um diese anwendung zu deinstallieren, mussen sie sie zuerst deaktivieren und dann im handy-menu unter 'tools' den 'progr. mananger ' offnen. wahlen sie dort 'o2 active' aus und wahlen sie 'entfernen' unter optionen
english (translated from google)
in order to deinstallieren this application, they mussen it first deactivate and then in the handy menu under ' tools ' ' progr. the one meadow ' off EN elections them there ' CO2 active ' out and elections them ' remove ' under options
but o2 doesn't appear in the manager????
only things in it are 2 games I downloaded.. that's it
black o2 music is what i have and i couldnt take out the o2 things mail,mp3player... even then languages en-de-tr why the hell i need t�rkish for, so what i did is flash the phone with self mooded 12 brd retail en-de-fr, voila everything is gooooooooooooood
caff some of o2 things are in A: drive (and it right protected )you can not take it out . la fin
willyboy666 wrote:black o2 music is what i have and i couldnt take out the o2 things mail,mp3player... even then languages en-de-tr why the hell i need t�rkish for, so what i did is flash the phone with self mooded 12 brd retail en-de-fr, voila everything is gooooooooooooood
so I have to flash the phones memory and reinstall it with '12 brd retail en-de-fr' (which I get from where?? )
I'm in the same boat as you caff. Just hoping someone can add to this thread to explain things just a bit better.
1.) Flash the phone (how? what program if one is needed? where to download?)
2.) 'self mooded'. Do you mean 'self modded'? I thought putting a different variant (Rolf Variant) was a bad thing. Correct me if I'm wrong.
To answer your question caff, you can download the software here: http://www.my-siemens.com/com.aperto/MySiemens/Files/Specials/hq/SX1_Upgrade_v12/main.html
if i have a music edition from o2, can i flash my sx1 with polish language version of software?if its possible how can i do that. its very important for me
I got an o2 music version of the sx1 and the o2 active thing was on the memory card that came with the phone.
Have you tried formatting the memory card or tried another card?
Hi !
My name is Frank and I'm from Germany. We have four O2-Music-SX1 in the family.
Thze only way to remove the O2 things , is to flash the SX1 with an unbranded Firmware.
If you need a Firmware, let me know it. I have a lot of Fws, from SW 12 up to SW 14, also McLaren without branding. All of them have the english language.
Best regards
Reddeer2000
You need the FW-updates with winswup.
Tell me what FW you need and I will send it to you or will send you the link where you can download it.
Cheers
Reddeer2000
well the rolf varient name is sx1_02-d-music-uk-de-tr_10_0005
.. just would like to get rid of the 02 active stuff since its in german and I cant read it (keeps trying to connect to the internet.. bloody annoying. plus I'm on a differnet network and pointless to use the 02 stuff..)
so could you post a link to whatever firmware would be suitable to replace it?
thanks
Hey I need help i have an o2 model and I need to flash it and I don't know how. Or I need the upgrade for the sx1_02-d-music can anyone help me? Send me an email at [email protected]
Why d'yall need to remove it?
It takes a few seconds to switch it off (its in the options on the application), and then its effectively gone, not using any memory at all.
The music part is awkward, but then again, try using OggPlay instead - the files are smaller, and the application is much nicer to use than the built-in MP3 player.
hello, Reddeer2000, I've sent a msg to you about winswup for O2 . Do you have the latest winswup version of O2-d-music, to which i will appreciate it if you can send me a download link. thx.
clonmult wrote:Why d'yall need to remove it?
well I wasn't on o2 but every time i swapped memory cards or turned the phone back on it would insist on crefreshing the o2 webiste, tried everything to get it to stop but it insisted on doing that. really pissed me off
