Does this happen on your n-gage?
2 replies · 1,637 views · Started 05 August 2004
1. I open music player, listen to a few songs.
2. I CLOSE music player.
3. I go to my menu, and games disappear (fifa, tombraider, whatever...)
4. Games don't re-appear until i put n-gage off and put it on again.
Is this normal? Does it happen on all n-gages?
If not, is there anything I can do to fix it?
- It used to happen on 32mb mmc that come with n-gage.
- I bought new 128mb mmc, it still happens.
- I formatted mmc, changed games, it still happens.
- N-gage is about four months old.
Please help me.
You can fix this problem this way.
format your mmc card in semenzi 6688i handset, the problem will be gone. try it. 😃
When the music player accesses the memory card, it does not allow other apps to access the memory card and the phone app that displays the menu cannot read and show the apps installed on the memory card. However, you shouldn't have to restart the phone to get them back (just closing - not just using the menu key to switch away from it while it still runs in the backgrouns - the music player should be enough).
