SMS icon stays on screen
1 replies · 2,889 views · Started 05 August 2004
Hi all,
I have a little problem with my 6600.
I Installed an application called Mobile Secretary. It turned out it wasnt what i was after do i decided to remove it. after doing so the icon the appears when an sms is sending, stays permantly on the screen. i am not sure if it is sending a bunch of sms's or wheather it is just a glitch. i have put the phone next to a speaker to see if i could hear the usual feedback and i cant, so this to me is a good sign. I formatted the phone after backing up all of my stuff to MMC. this got rid of it, but as soon as i did a restore from MMC it reappears. i wouldnt mind so much if i didnt have all my contacts that need to be copied back accross, other wise i would leave it fresh after the format, but i do have to do a restore. i have gone thru and removed all traces of mobile secretary from my phone that i could find using FExplorer. but it did no good. i downloaded "Switch" a app that shows all running processes (kinda like ctrl+alt+del in windows) i found a process called "msexe" which i am not sure if it is part of mobile secretary, i was wondering if someone could post a list of the nokia specific procses's that the phone needs to run so i can compare.
If any 1 has any suggestions in how to fix this problem or how to extract individual files from the Backup on my MMC i would greatly appreciate hearing them.
Thanks in advance.
