i found out that if you send a message with one ! at the beggining it make crazy!!!!!if you send like : !Fuck you. you will recive : message fuck you. from(the number you send the message at) succeeded. .I don't know if the other one recived the message.It's crazy😊 if the message is recived then this is a form of report if not it's CRAZY
Anyone have this???
Try Please
one interesting bug in the n-gage
:d
Wirelessly posted (Nokia N-Gage: NokiaN-GageQD/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Which game deck does this supposedly work on? The N-Gage or the QD?
And whatever really happens (the original poster's description isn't very clear about what actually happens), if something happens 😉, is probably no N-Gage bug, but his/her operators messaging center is using the '!' character as some kind of special command for something (whatever the behaviour now is).
Can you try the same and then post what hapened to you.
The person i sent the message at recived the message to.
Try
from the msg report. sounds like the line is being taken as a subject.. eg email?? 🙄
