How do I use the midis on my mmc as a ringtone ? I cant select them to use them as one? 😊())()(
mmc midis
phoebad wrote:How do I use the midis on my mmc as a ringtone ? I cant select them to use them as one? 😊())()(
Select a profile, edit it and assign a ringing tone for that profile.
You can also assign a specific tone to a contact. You just have to explore.
Wirelessly posted (Nokia N-Gage: NokiaN-GageQD/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
If you're storing ringing tones on a multimedia memory card (MMC), ensure that the files are stored in E:\Sounds\Digital\, otherwise the ringing tones won't appear in "Profiles" when you're trying to set them as the current tone; if your ringing tones aren't in the correct folder, just use one of the many file explorers that are available to move them to the correct directory. All of the above applies to both the N-Gage AND the N-Gage QD with True Tones OR polyphonic tones.
