hi guys, i'm using nokia6600 v3.42. Nowadays experiencing a new kind of problem. whenever i enter any sort of meeting or memo or anniversary in my calendar, it isnt saved. when i reopen calendar, its gone. can any1 suggest any solution. if i format my phone would it solve the problem? i've some apps on my memory card which store some files on phone memory, wud they be corrupted in this format attempt. by the way, i formatted my phone once n psiloc apps r not taking the keys as it says "app expired", so my money on that is already gone. can i expect some more?
Calendar entries not saved
i m 100% sure you have Rally Pro install in your mobile. this game deletes all calender entries. so simply uninstall rally pro from manager and never reinstall it. Then your calender will be 100% ok.
QUOTE=akkies_2000]hi guys, i'm using nokia6600 v3.42. Nowadays experiencing a new kind of problem. whenever i enter any sort of meeting or memo or anniversary in my calendar, it isnt saved. when i reopen calendar, its gone. can any1 suggest any solution. if i format my phone would it solve the problem? i've some apps on my memory card which store some files on phone memory, wud they be corrupted in this format attempt. by the way, i formatted my phone once n psiloc apps r not taking the keys as it says "app expired", so my money on that is already gone. can i expect some more?[/QUOTE]
