Hi -
The driver which comes bundled under the CD doesn't support Windows 2003 platform.
Any idea where can I download drivers for Windows 2003 Environment.
Rubal Jain
http://www.Rubal.Net
Hi -
Rubal Jain
I need for DKU-2 Cable
There isn't one. Does Windows 2003 have a "compatibility" mode that allows the Windows 2000/XP driver to be installed? Right-click on the DKU-2 installer, open the "Properties" menu and see if there's a "Compatibility" tab, like on Windows XP.
No .. Windows 2003 isn't there in compatibility list .. Any Trick I can install drivers on windows 2003 ... Or any alternate S/W which I can Install..
Maybe I didn't explain it clearly enough?
From the "Compatibility" list, pick Windows 2000 or Windows XP & then try to run the installer.
At least on Windows XP this method can be used to "lie" to software that it is running on Windows 2000, Windows NT, Windows 95, etc.
I would imagine that a similar facility exist on Windows 2003; i.e., you can set it to lie to apps that it isn't Windows 2003, but Windows XP, for example.
N/A wrote:Maybe I didn't explain it clearly enough?From the "Compatibility" list, pick Windows 2000 or Windows XP & then try to run the installer.
You have explaned it clearly enough. I Can find the tab. I tries selecting every option one at a time - but the install shield package still fails with a message about service pack 1.
This does not work!!
Yeah im using windows 2003 too but it does not work i tried and gave up months ago, we should wait until windows 2003 sp will be released. Idiot nokia does not know that windows 2003 released ages ago.
I've never heard of Windows 2003 ??
Windows 2003 is an upgrade to Windows 2000 server version(s). The workstation upgrade is Windows XP (which is not available in a server version).
nice drivers
