Is there a way to change the backlight duration on the 7610?
Thanks for your help...
Can we set the Backlight time?
Jamon wrote:Is there a way to change the backlight duration on the 7610?
I second that request, i know it will run the battery down that little bit faster but hey 😎
No, but you can install FExplorer (http://www.gosymbian.com/) and turn the backlick on in its Tools menu & then leave it running and switch to other apps and FExplorer in the background will keep the light on until you turn it off (or exit FExplorer).
